So some of you will remember that back in late September last year I had melted wiring in the Z3 due to the light inside of the boot shorting but the fuse not failing when the light's wiring was shorting which could have ended in a full on fire.
The fuse for the soft top motor did burn out when the wiring for that circuit melted from the heat (the wiring for the soft top motor is wrapped up with the boot light wiring and all the other wires that go from the rear up the fuse box in the engine bay).
The fuse for the boot light was a Halfords one. The fuse for the soft top motor a genuine one.
So I've managed (finally!) to get the car over to an auto electrician to repair it and upon looking at at he said it was the fuse at fault - apparently some replacement fuses are not the right materials or even the wrong rating. If the fuse worked it would have simply burnt out and not allowed the continual shorting which caused the damage.
He has got the car running again to ensure it was just the boot light which was the issue and nothing else and will now start the long task of redoing all the wiring that was affected. The worst of the work is under the fuse box which needs stripping (if you have seen how many wires are under your fuse box you really wouldn't want to do that job!). Luckily it's just the section of loom that runs from front to rear and not the main loom that goes behind the dash.
I'm glad it's going to get sorted but highly annoyed such a cheap item I took for granted caused such a big problem.
A cursory search of the Internet brings up a few similair stories and some retailers doing recalls of dodgy fuses.
I didn't think anything of buying fuses from Halfords but would have avoided poundland for example.
Now where does one buy proper fuses from then?
