For Sale BMW Z3M 1998 S127 APK
raymond
EAST SUSSEX
Z3M
Sadly I have decided to sell my Z3M. I bought the car in April after it had been stored for three years and put it back on the road. I have replaced the radiator, the oil cooler and some hose pipes and had the car serviced. Since then I have had the ECU overhauled and the brake cables replaced. Underneath the car there is no rust. However the body work is a little scruffy. Some minor pieces to the car are missing ie plastic engine undershield The mileage is at 149000 which is an average of 8000 miles per year. It runs well and does not seem to burn any oil. The air con does not work but everything else seems to. The car had the clutch replaced at 125000 and the boot floor was welded at 128000. I have all the bills for the car along with the service manual. The last owner had the car detailed at http://www.spiderve.com/bmw_roadster.html but these pictures make the body look much better than it really is. This M is the cheapest M roadster on the market and I am looking for £8500 http://www.bmwmregistry.com/detail.php?id=15539
  • Vehicle make BMW
  • Vehicle model Z3
  • Date first used 31 December 1998
  • Fuel type Petrol
  • Colour Blue
MOT history of this vehicle
  • Test date 10 May 2017
  • Expiry date 9 May 2018
  • Test Result Pass
  • Odometer reading 147,867 miles
  • MOT test number 6193 6293 7833
  • Advisory notice item(s)
    Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
    Offside Rear Tyre worn close to the legal limit (4.1.E.1)
    Parking brake lever has little reserve travel (3.1.6b)
  • Test date 28 April 2017
  • Test Result Fail
  • Odometer reading 147,822 miles
  • MOT test number 5240 3334 2653
  • Reason(s) for failure
    Windscreen washer provides insufficient washer liquid (8.2.3)
    Offside Front position lamp(s) not working (1.1.A.3b)
    Nearside Parking brake is not capable of being maintained in operation by direct mechanical action only (3.1.2)
    Offside Parking brake is not capable of being maintained in operation by direct mechanical action only (3.1.2)
    Parking brake: efficiency below requirements (3.7.B.7)
    Offside Tyre worn close to the legal limit (4.1.E.1)
  • Test date 28 July 2014
  • Expiry date 27 July 2015
  • Test Result Pass
  • Odometer reading 147,411 miles
  • MOT test number 5294 5920 4233
  • Test Result Fail
  • MOT test number 4368 1990 4231
    Offside Front Headlamp aim beam image obviously incorrect (1.8.A.1b)
    Front Windscreen washer provides insufficient washer liquid (8.2.3)
  • Test date 31 May 2013
  • Expiry date 31 May 2014
  • Test Result Pass
  • Odometer reading 144,686 miles
  • MOT test number 1059 4195 3193
  • Test date 28 May 2013
  • Test Result Fail
  • Odometer reading 144,684 miles
  • MOT test number 8179 2844 3132
    Nearside rear parking brake recording little or no effort (3.7.B.6a)
    Offside rear parking brake recording little or no effort (3.7.B.6a)
    Nearside Front position lamp(s) not working (1.1.A.3b)
    Nearside Rear position lamp(s) not working (1.1.A.3b)
    Nearside Front coil spring cracked (2.4.C.1a)
    Nearside Front Macpherson strut has excessive movement at the upper attachment (2.5.A.1c)
    Offside Front Drag link end ball joint has excessive play (2.2.B.1f)
  • Test date 1 June 2012
  • Expiry date 31 May 2013
  • Test Result Pass
  • Odometer reading 138,217 miles
  • MOT test number 6673 1375 2178
    Nearside Side repeater slightly discoloured (1.4.A.2f)
    Nearside Front coil spring corroded (2.4.C.1b)
    Offside Front coil spring corroded (2.4.C.1b)
    Nearside Rear Shock absorber has a light misting of oil (2.7.3)
    front wiper blades starting to smear windscreen
    front washer jets getting weak
  • Test date 30 May 2012
  • Test Result Fail
  • Odometer reading 138,145 miles
  • MOT test number 7280 1185 2149
    Offside Rear fog lamp not working (1.3.2b)
    Nearside Headlamp aim aimed so that it dazzles other road users (1.8.A.1a)
    Offside Headlamp aim too low (1.8)
    Centre Stop lamp has less than 50% of the light sources illuminating (1.2.1b)
  • Test date 4 April 2011
  • Expiry date 23 April 2012
  • Test Result Pass
  • Odometer reading 128,910 miles
  • MOT test number 6492 2429 1067
    Offside Front Anti-roll bar linkage rubber mounting deteriorated but not resulting in excessive movement (2.4.G.2)
  • Test date 1 April 2011
  • Test Result Fail
  • MOT test number 9454 6139 1093
    Front Front position lamp(s) missing (1.1.A.3a)
    Offside Front Steering arm has relative movement at its fixings (2.2.B.1h)
  • Test date 24 April 2010
  • Expiry date 23 April 2011
  • Test Result Pass
  • MOT test number 8619 1471 0120
  • Test date 16 March 2009
  • Expiry date 15 March 2010
  • Test Result Pass
  • Odometer reading 107,838 miles
  • MOT test number 9338 4537 9083
    Front Tyre worn close to the legal limit (4.1.E.1)
    Offside Front Tyre worn close to the legal limit (4.1.E.1)
  • Test Result Fail
  • MOT test number 1229 5537 9465
    Offside Front Front position lamp(s) not working (1.1.A.3b)
  • Test date 19 December 2008
  • Test Result Fail
  • Odometer reading 104,982 miles
  • MOT test number 5944 5435 8324
    Nearside Stop lamp not working (1.2.1b)
    Offside Stop lamp not working (1.2.1b)
    brake disc in such a condition that it is seriously weakened (3.5.1i)
    Rear Brake pad(s) less than 1.5 mm thick (3.5.1g)
  • Test date 17 September 2007
  • Expiry date 16 September 2008
  • Test Result Pass
  • Odometer reading 101,809 miles
  • MOT test number 3919 3046 7499
  • Test date 15 September 2007
  • Test Result Fail
  • MOT test number 3700 4875 7278
    Rear Registration plate lamp not working (1.1.5c)
    Offside Rear Tyre has ply or cords exposed (4.1.D.1b)
    Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
    Rear Parking brake is not capable of being maintained in operation by direct mechanical action only (3.1.2)
  • Test date 5 June 2006
  • Expiry date 4 June 2007
  • Test Result Pass
  • Odometer reading 87,953 miles
  • MOT test number 2011 5675 6430
Search again
Open Government Licence
All content is available under the Open Government Licence v2.0, except where otherwise stated
© Crown copyright
Low Rider
Your M looks great shame you've decided to sell. All the best with your sale
Mnbrennan
Aylesbury
BMW M Coupe / 2.8 roadster
If I had the money I'd snap this up. A lot of car for the money
BMBabe
Staff member
Community Admin
Aylesbury
With alllll that history its worth a lot more!!!
Good luck with the sale :thumbsup:
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
Someone will be getting a real bargain! Wish the exchange rate was more favourable!! GLWS JIM
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
A lovely Z :p
Good luck with your sale :)
ZTec
Llantwit Major
So little money for so much car, good luck.
Tfp
Cambs
Saw it pop up on Ebay today.
I'd add a little more info about the boot repair.
At the moment it just says "boot floor welded"
To us we know what that means, but to someone that doesn't know they may be thinking why it's been done.
Just a thought.
oldcarman
Canadian Zeds
Hang in there, you'll get your price or those guys don't know a great deal when they see one!! JIM
lightning
Gone from Ebay....sold already? I bet it has at that price. £2,000 spent would make it worth £12-14,000
raymond
EAST SUSSEX
Z3M
Just waved goodbye to her as she went off towards Heathrow to her new home. Her new owner also has an Z3M coupe so she will not be lonely. Just hope he joins the forum. I will never sell a car on Ebay again. 40 messages and counting.
  • Like
Reactions: Tfp
lightning
At that price your phone would have melted if you put it on a site such as Autotrader where people could call you!
With Ebay at least you can reply without having to speak to anybody.
Mnbrennan
Aylesbury
Hi, who's the coupe owner? Assume they're on the coupe site?
raymond
EAST SUSSEX
Z3M
Sadly due to privacy I cannot name him but I am trying to get him to join the forum. He had stripped out the car and rebuilt it. His theory on why the coupes are worth so much more is that they were built in Germany and not in the USA. I will keep working on him to join
