They were from my prefacelift widebody. Just replaced the outer sills and rear wings and didn't want to put them back on.Quite rare... Did you not fancy fitting them Jim? I am still wondering if anyone has altered the rear ones to fit the face-lift.?..
should fit both with mod, sills and lower edge of the wings are the same are they not?Quite rare... Did you not fancy fitting them Jim? I am still wondering if anyone has altered the rear ones to fit the face-lift.?..
Fronts fit but I think I read the rears required chopping about to fit on a face-lift. I have a set but as they are quite hard to come by I'm not sure if I could cut them about if I then went on to change my mind on the look of the rears ... Fronts look good in my opinion and certainly help deflect stones away from the paintwork..should fit both with mod, sills and lower edge of the wings are the same are they not?
Well you learn something new every day I though they fitted both pre and post face-lift.Fronts fit but I think I read the rears required chopping about to fit on a face-lift. I have a set but as they are quite hard to come by I'm not sure if I could cut them about if I then went on to change my mind on the look of the rears ... Fronts look good in my opinion and certainly help deflect stones away from the paintwork..
