eBay bmw 5x120 stance wide z3m 9j wheels
windym
On eBay fairly rare will these fit a Z3?
Andy
Just found and read the advert. Definitely not. It's 4 rears and on the front they would stick out ridiculously.
The only easy way to run style 40 rims on a standard Z3 is to run 4 fronts. Otherwise you need to roll the arches on the back.
Hi 9J
Andy
That's the width of the rim. There are 3 dimensions needed. Rim size, width and offset. Without all three it's not possible to comment.
windym
Hi, waiting for a reply from the seller, they do look smart though.
Andy
They do look smart but they won't fit. Both front and rears will be outside the arches, the fronts worse than the rears.
5harp3y
The fronts are 7.5j et41 so the same as most z3 wheels
The rears are 9j et8 so they will poke out nearly 40mm more!
5harp3y
so in total unless you have tiny stretched tyres and some decent rear camber they arent going on (front or back)
The advert in question is four rears, not a standard staggered set. So would be et8 9's all round.
spurs fan in a coupe
As others have said, the ones in your original post wont fit without really fouling the arches.
I have this replica set for sale, or you can try and source 4 front wheels (spacers for the rears would look better)
Cheers
https://zroadster.org/threads/17-inch-z3m-wheel-replicas-fit-non-m-models.10453/
Recently found out tat one of these wheels has a flat spot, so will need a refurb, so willing to accept a sensible offer bearing this in mind.
