jaguartvr
- Joined
- Jan 9, 2017
- Points
- 95
I have an old 5.3 V12 jag running 6 weber carbs, my problem is that they do not provide enough vacuum to operate the brakes. Ferraris of the 70's suffered the same problem so they had a vacuum pump running off the end of the camshaft.
The webers only have the front 2 carb intakes tapped to take the vacuum pipe, individually they draw about 3 hmg of vacuum, with a y splitter and one way valve thepull about 5hmg. I need at least 29 hmg. Would drilling and tapping the other 4 carbs increase the vacuum if they were all connected together?
I have tried fitting an electrical vacuum pump but it is very noisy, seems to be on too much and runs so hot that you would burn your hand if you touched it.
In desperation, I have bought a set of 4 SU carbs from an E-type and had started to fit them when I wondered if daisy chaing the webers up together would be better.
Any one have any bright ideas?
Thanks
Thanks
