My airbag module is toast,it has been checked and is not repairable, they have got me a repaired module, but results from the original pointed to a major short that caused the damage. I do not want to connect the replacement up and trash it, has anyone got a module that they have spare or will sell cheaply, I have done as many checks on the connections and wiring as possible and cannot find any faults.I just need a dummy to try to see if the fault exists (if it does it will may toast the unit )or I have cured it before I connect up the new module. The module part number is original 67778386192 or superseded by 65776908896. Thank you it’s an awkward position to find yourself in, chicken and egg.
