ABS AND ASC LIGHTS ON HELP???
pete59
newark notts
Advise please,not used the car all week and was fine when i put it away now when i started up today the ASC and the ABS Orange lights stay on moved the car ,and restarted 3/4 times they dont go out,any advise before i book her in at my local gararge.thanks pete
stevie_a
Glasgow'ish
I know it may be a silly question but
You have tried to press the manual asc override button on the dash ?
start simple
worth a thought??? :ymblushing:
Pete
I had exactly this problem after a flat battery. The cure was a long run (circa 60 miles). I tried to clean the wheel sensors but they were well and truly stuck and I didn't want to risk shearing them off. My theory was they were ok when I parked up, why should they become dirty being parked in the garage?
I also had the added complication of the brake fluid warning light as well even though there was plenty of fluid in the reservoir.
Give it a good run Pete and see how it goes.
Cheers Dave
Daz999
Dromore, Co.Down
BMW Z3 2.2 Sport
I had this same problem, I took to my indie mechanic who attached the code reader. It turned out to be a faulty ABS sensor on one wheel and thankfully not the ABS pump.
Important to note that you may not have ABS or DSC at the moment, until its fixed.
