hey all!
Well you know what they say - get one problem fixed and another one appears!
Id successfully changed over my faulty speed sensor with a huge thanks again to @Brian H and my new Respray courtesy of graham at the touchless car wash!
But now I fear I may have a little engine trouble!
Just driven felix over to my friends and noticed that something didn't feel right when I was sat with my engine idling at the traffic lights. I turned the music off and sure enough, my car is revving by itself. Ive got the hand brake on and gear into neutral. The engine sounds gritty and like it's not running quite right.
I did have an incidence of cylinder misfire about a year ago in autumn time, but the car was really noisy when it started up when that happened (which it didn't do this time) and that never happened again after that incident, which I put down to the damp autumnal weather and wet on one of the ignition coils.
I restarted the car and at the next set of lights put the handbrake On and gear into neutral and it kept doing it. Parked up at my friends and sat in it idling and it just doesn't sound or feel right. Something is up!
Rather worried with it being something engine related - it's ok when it's a sensor or a light because you think hey I can fix that just by replacing that part, or I can put up with it like that for a while.
Just recently had a full system flush and oil change and a new sump gasket and coolant tank. All seemed to be fine and dandy.
Any help greatly appreciated!!
