Wanted 51168407985 - Set of covers, oddments box, subwoofer lid Black
Papaganoosh
American Zeds
Maryland
M Roadster
Having trouble finding this part that tops off the subwoofer area. I removed mine to soundproof it and ended up popped holes in the top putting the screws back in :banghead:
Worst case if I can't find a replacement is to have it wrapped in leather to cover up the damage. :bag:
spurs fan in a coupe
They are crazy money from BMW, I have a set of OEM roll hoops with the HK sub enclosure (no sub or brackets), but I think you'll struggle to find someone willing to split a set - I'll sell it whole.
PM me to discuss.
Cheers
Papaganoosh
American Zeds
Maryland
M Roadster
Johnwayne
"M" Roadster
Looking good Lewis, the upholsterer made a great job in covering the panel. Any joy in finding the deflector screws?
Stay safe my friend :whistle:
Tyler
Your lid really looks great covered in leather. I've seen a few tan lids in leather. Did BMW offer them that way, do you happen to know?
Rodders67
American Zeds
Indy
Z3M
Anyone have picture of subwoofer cover pre 4/1999 when apparently they replaced my metal tab system with simpler plastic tab and slot version?
in back of photo you can see metal tabs…
Rodders67
American Zeds
Indy
Z3M
I know this is old post, but I have similar issue trying to get this subwoofer lid off.
I finally tried the opinion of pullling straight up, but lid is now fractured. There appears to be design change prior to April 99 which entalis a lid subframe mounted with metal (not plastic) tabs. Can you share how you got lid off???
Rodders67
American Zeds
Indy
Z3M
I have gotten cover off… had couple things working against me. Two of the lid subframe screws… were no longer in the subframe… so when I pulled up, the frame separated from cover.
While pilling plugs from A pillar, I realized my super skinny needle nose would slide between both sides of center tab. Pulled up … boom. The force applied directly to tab frame did it with no further breaks.
Now I pulled subwoofer box and discovered the subs are in great shape.
any ideas why they sound like garbage with the aftermarket JVC KD-BT11?
SW settings
Line Out = Subwoofer
Low Power = 30watt
phase = 180
Frequency = MID
Thanks…
