Hey there I’m currently in the process swapping a 350sbc and a th400 into my 1997 z3, here’s a write up of my process so far
got a 350sbc and th400 trans from a running 1975 corvette for a few hundred dollars
did a general refresh on everything , new gaskets, new oil pump, intake manifold, carburetor, spark plugs, wires and distributor along with just cleaning the entire motor with degreaser and repainting the block
got the motor running on the stand after setting the timing and wiring up my switch panel and started on dropping the z3 drivetrain
used a bunch of degreaser to clean the bay and installed my new sikky ls swap steering shaft for more clearance
got to work on the custom gauge cluster, cut the original housing and used a metal plate to give it an oem fitment
Moved the switching panels from the engine stand over to the center console panel
Sliding the engine and trans in
welded the motor mounts in and got everything mounted
finished the wiring for the inside switches and gauges and have everything from the engine wired up
Shifter for the trans is installed just need to add a plate in between it and the center console to clean up the looks
Now with the engine and transmission mounted in time to work on the cooling system, new crank pulley, and water pump pulley
