Rebody 250 California build thread for dummies
Pond
Spaldingski, Lincs
Z3 project
I had confirmation from the insurers on the agreed value today, following me sending them pictures and info last week.
In the agreement letter, they asked if I wanted to increase the value, which I thought was bizarre.
mikeyH
South Devon
2.2 Z4 E85
Good news, it's obviously worth more than you think it is :) :thumbsup:
Pond
Spaldingski, Lincs
Z3 project
Only problem is it comes at a cost. If I increased the agreed value, the premium goes up. Nothing is free in life!
Duncodin
Pontrhydyrun - in Crow Valley
M44 FrankenZed
and the heater control wires are akin to wrestling with a very angry snake. Doing all this in 32c heat doesn't exactly help either!
OK. And having wrestled with the angry snake - what did you do with it? I don't see your heater controls in any of your pictures?
Pond
Spaldingski, Lincs
Z3 project
Heater controls are below the centre gauge pod. Three 'choke knobs' on braided wire. All are push/pull. One for heat, one to adjust the internal flap for windscreen or footwell vents. The third is a dud in my case, as the amount of aggro to connect it to the other flap wasn't worth the negligible benefit.
The BMW heater has a little microswitch which opens and shuts a solenoid for water to flow around the matrix. I couldn't find a way of re-using this, so mine has water flowing around the matrix at all times.
The vent controls are the three central ones. Far left is an aux socket, far right is the hazards and the other is the fan speed switch. I don't have an A/C switch as I didn't want it.
Duncodin
M44 FrankenZed
On a standard (ie non messed with zed) how is that water flow valve controlled? I expected it to be a pull/push cable that could partially open close the valve - but you called it a solonoid. So is it just fully open or fully closed? Is there a thermostat that opens/closes it based on the position of the blue-red knob.
So in your case it's always fully open and you avoid cooking in summer by simply closing the flaps?
Pingu
There isn't a water flow valve, only air flow ducts. The water flows constantly through the heater matrix, but air only flows over the matrix and along the ducting when the appropriate setting is chosen.
ChrisD
Evesham
M44
The heater control valve allows coolant to flow into the heater matrix. It looks like this:
It is mounted in the rear of the engine compartment. It’s somewhat buried but it can be seen.
The heater control valve is controlled via an electrical switch on the temperature control dial, as shown in the schematic below:
Sorry I don’t have a better picture:
Pond
Spaldingski, Lincs
Z3 project
Yes, there is a microswitch which is made/broken by a small moulded part on the BMW heater control wheel.
Too complicated to use it when changing the heater controls TBH, so I binned mine, which means the valve/solenoid is always open!
Pingu
Yes there is. :thumbsup:
I thought it was used for bleeding. You're right, though. The valve is opened when the temperature is switched away from cold (wiring diagram says "switched to maximum", but the microswitch is near the cold setting).
It opens flow into the heater matrix.
Another school day for Pingu :thumbsup:
