M Tax strikes again
Pingu
Messages
1,077
Z3 (1.8 - 3.0 + S52) fuel pump - 16146756323 = £100
M Roadster/Coupe (S50) fuel pump - 16142228037 = £400
M Roadster/Coupe (S54) fuel pump - 16142229672 = £325
Guess which one I might need? :eek:
Althulas
Messages
3,233
North Oxfordshire
M Roadster
The random BMW pricing drops yet another bombshell which has doubled in 6 years. I remember this post Pingu about Dino selling a Walbro 255 which he used prior to his V8 conversion https://www.zroadster.net/forum/viewtopic.php?t=40982 I don’t if that info is of any use to you. Maybe a PM to Deno to see if it was any good for the S50.
Pingu
Messages
1,077
This is the tank. I need the pump.
It looks in very good condition, though.
Pingu
Messages
1,077
I've had a reply from the seller. Unfortunately, there isn't a pump with the tank.
Althulas
Messages
3,233
North Oxfordshire
M Roadster
Sorry about that I thought it was worth a try. Did you consider speaking to Deno about a possible alternative fuel pump?
Pingu
Messages
1,077
Deffo worth a try. Deano doesn't have one, but the fuel tank guy might have one, as his fault wasn't the same as mine. There is a possibility that I might be able to make one out of two.
Pingu
Messages
1,077
The fault was Fuse 18 (15A) was blowing every time I switched on the ignition. Fuse 18's only function is to protect the fuel pump.
I've removed the pump unit and stripped the unit down, so the pump is on the bench. The pump works perfectly and draws 1.30A continuously. I then suspected the relay, so I removed the relay - and it works perfectly.
Then I had a brainwave - I ran the pump and put my finger over the end. The current shoots up.
Conclusion - fuel line is blocked. I'll blow some compressed air through the pipes and, with any luck, the most that I'll need is a new filter.
