Help EBC Red stuff brake pads
Paul Rice
Messages
5,204
Doncaster
Z4 2.5
Fitted these to mine. i have heard of problems initially with noise?
Well mine seem to be eating the discs as well?
The noise sounds like when the pads are down to metal and i have iron filings in the inner of the wheel.
How long do they take to bed in and should i put the original healthy pads back in?
Messages
39,332
Z4 3.0 Auto
Have you got drilled and grooved discs on Paul? I used EBC pads and painted them yellow sometimes I get a little noise from the brakes but the discs are still like new. When I fitted the new brakes on Ants car after he damaged his arm the directions said to really hammer them from new to burn the coating off the discs.
Paul Rice
Messages
5,204
Doncaster
Z4 2.5
The discs are grooved and dimpled and have about 5 k of wear, just replaced the pads the noise is very loud and quite embarrassing
Messages
39,332
Z4 3.0 Auto
Is it possible you have picked up a stone, or is it both sides and right across the discs contact area mate? Is the disc surface rough or smooth?
Paul Rice
Messages
5,204
Doncaster
Z4 2.5
Its both sides, i cleaned the discs of Surface rust with brake cleaner so the discs are clean and smooth. Unable to drive far just around the block as planning on Taxing in March so will probably give it a run somewhere quite (well quite till i get there) then if no improvement will put the Pagid ones back on. One chap on Piston heads recommends heavy braking 60 down to 20 then 100 down to 20 then leave car for 2 hours then repeat. This has drawbacks one being don't have access to a racetrack or Runway where you can do 100 legally. EBC say it can take up to 1500 miles which seems a lot
Rha
Messages
3,964
Z4 coupe sport.
Had red on my Z3 for years Paul, with groove-drilled discs and did have to run them in harshly at first getting noise too.
The main problem I had was that until they’re warm/used a bit first thing they tend to fade a little on first application so be careful up to first braking point. Other than that they were real nice have now got yellow stuff pads on the Coupe and they’re even better but don’t give you the same amount of mileage. I personally wouldn’t go back to red stuff as I’ve found on advice from @Lee the yellow are better. You’ll get more dust from the yellow stuff but think it’s a small price to pay IMO.
Roy.
Messages
3,807
Z3 Roadie 2.8TU
Roy.
Just to follow up the advice I gave Roy, unless your going to track I wouldn't bother with Reds unless your driving is very spirited.
The reds and yellow pads will eat discs due to the aggressive nature of the material It's a trade off for such good braking. I did a set of discs every 3 sets of pads but that was including track time. They will also be noisy if you lightly use them all the time.
  • Like
Reactions: Rha
Paul Rice
Messages
5,204
Doncaster
Z4 2.5
Cheers Lee. think the pagid ones will be going back in
Messages
39,332
Z4 3.0 Auto
I used these pads Paul, very happy with them. Hardly any dust, little disc wear and great stopping.
Messages
7,813
Forest of Dean
Z3M and Z4 (e89)
RED stuff have a run in coating on them, they are noisy initially. I have used them on the M for the last 5 years and had no issues, great pads IMHO also done 30k on the same discs (Black Diamond 12 grooved) with RS pads (2nd set). Will defo get another set of pads out of the discs. I am guessing if you are going down the Red or yellow stuff pads you need to put decent discs on to combat the wear?
Messages
7,813
Forest of Dean
Z3M and Z4 (e89)
Like the idea of better braking but the noise is un bearable
How many miles have you done on them Paul? The brake in surface is very abrasive and will make a hell of a noise, it needs to be worn off, takes quite a few miles if memory serves, especially if you are light on the brakes and takes longer on the rears
Paul Rice
Messages
5,204
Doncaster
Z4 2.5
No miles really as SORN at the moment just a run round the block. The noise level is really high getting strange looks from passes by, the worrying thing is the amount of metal filings that's coming off assuming the Discs.
Messages
39,332
Z4 3.0 Auto
It’s not coming off the discs Paul it’s coming off the pads. You would believe the stick I had to give Ant’s car to bed them in for him ready to collect from my place. I wouldn’t give up on them just yet.
Messages
7,813
Forest of Dean
Z3M and Z4 (e89)
Hi, keep them in you need a good run out to wear them in, the brake in surface is there to give you instant braking efficiency from the pads from new/cold while they bed in. Trust me the noise will go away. :thumbsup:
