#ZedShed Dave’s Z3M Coupe
Messages
3,879
Z3 Roadie 2.8TU
With Millers M coming to an end it was time to collect a celebrity in the M world, a stunning Estoril Blue Z3M Coupe with plenty of Ac and Hamman bits. On my drive home which was only 20mins it was very clear the rear beam bushes were gone, I could feel a subtle clunk on bumps through the seat, also she just felt loose overall.
Owner: @137699
Today seems to be an M kinda day. Another M popping in to get an idea of what we do and book in for some work.
We did a few more jobs on Millers M before moving her outside. Then it was time to move Daves coupe in and see what we’re up against next week.
I remember years ago when I had my M seeing the coupe guys modding their lights with these projector kits.
stunning interior with some nice touches.
I love this mod, tyre indicator system powered from the cig lighter.
on each wheel label.
we also have a rear lower diffuser to fit, these really finish the rear.
Wheels are in the best colour combo, I think this colour came on the S54 as standard. We also noticed the rear tyres are down to the 1.3mm mark so could do with a fresh pair soon.
Now the wheels are off we can see what to expect next week. Some light corrosion, relatively new rear shocks. Can see the roll bar is an upgrade, maybe a HnR under the dirt ?
Passnger side marginally better.
the most crucial part to the trailing arms looks in good health, we’ve started calling it the gooch area =))
I can’t foresee any issues with the rear. The front on the other hand looks very tired.
will need to measure the disks as I can feel quite a large lip.
these brake lines will need to be cut off. Not a chance in hell of these undoing.
All in a days work in the shed :) look forward to making a start Monday.
Messages
139
Thanks Lee for my thread! Mega excited to watch this unfold....
Yes they are H&R ARBs on there & indeed when I had the wheels refurb'd I had them done in S54 style black/chrome finish (previous owner had done them in black - which I wasn't a fan of at all)
Interested to see you noted the knocking through the seat- I had the seat bushes done last year and assumed it to be that one hadn't been done properly and that's why I could still feel the knock.... didn't realise it was potentially transmitted vibration from the suspension!
Front brake pipes were advisory on last MOT - so no surprise there either!
Grabbed a big bag of popcorn - let the show commence!
BillH
Messages
3
Hi Lee
Thanks for an informative couple of hours this morning - great meeting you both and I'm really looking forward to seeing my underside stripped out 😂😂😂 oh, and those spacers just look great - maybe a 10 min job for you guys, half a day for me!
Reading all the updates and will follow them all now - just look after your back.
Cheers again
Bill 👍
Messages
3,879
Z3 Roadie 2.8TU
Day 1 of Daves build went really well. Nothing really gave me too much trouble. I thought I would break myself in gently and started to remove all the front end.
All the main hardware came off without too much fuss.
love these top mount covers.
With the front end stripped it was time to break everything down to component form. See what’s got any life left and see what’s being binned.... safe to say Dave got his money’s worth.
Drivers side, brake lines both have blanks on them for the time being. Will swap these out later
First to strip are the knuckles or hubs as some people call them. Big boy nugga needed to remove the nut.
Least the front wheel bearing slide off, or at least should. Stripped ready for powder coat
Other side gave me a bit of bother. The rear bearing race didn’t want to leave.
Once they were split it was the shocks next.
First one loaded. These are in a right state.
collapsed top mount.
Both sides were like this, bearings were so dry I’m not surprised.
Was there any life in the shocks I hear you ask
Made me chuckle, going by the sticker on the shock these are the originals from factory.
I also think the front drop links are too long, they should be a few inches shorter, these old ones measured a whooping 9” (-steady boys =)) ) I’m pretty sure with the HnR roll bar they should be shorter, these held the roll bar at a strange angle pointing downwards, will check this.
so now I have a nice big pile of bits ready for coating. I better get ordering the front end bits. I’ll wait till I’ve got the rear end out and do one big drop off to the coaters.
we’ve got quite a bit of new hardware to order.
tomorrow the rear end tear down starts.
137699
Messages
139
Great work Lee!
Scary to think I’ve had that airborne on more than one occasion last summer and used it at 3 figure speeds on some twisty tarmac😁
I can only begin to imagine what it’ll be like with suspension that actually works😂
BillH
Messages
3
Following this as I saw the gleaming car last Saturday. It's a lesson in how to breathe new life into tired running gear.
Keep it up Zedshed 👍👍👍
  • Thank You!
Reactions: Lee
Messages
3,879
Z3 Roadie 2.8TU
Nice big juicy update. I always say now we’ve worked on so many zeds when we disassemble they tell us a story and this coupe didn’t disappoint, what’s more reassuring is it ties in with what Dave knows about the car.
Now the front is apart we turned our attention to the rear. With the arch liners off we can see the the condition of the beam bushes. One side was sat higher and one side was sat on the plate...odd
This is drivers side and turns out has been replaced in the past, why not replace both beam bushes...
Now the passenger side. In a right state de laminating and sat on the plate.
Drivers side arm had been replaced and it’s clear by the number a breaker had written on it.
with the exhausts out you can see so much.
someone did a temp repair on the handbrake cables. Hiding a split under some tape. Quite common.
Moving on, I only had a little trouble with the side bolts holding the beam plates. Within 2 hours the subframe was out.
Now it’s out we can begin the strip down.
removing old bushes. These were both unbranded bushes so have been changed at some point at different times. The passenger side core nearly fell out.
Next up was a strip down of each arm, we remove everything so it can be grit blasted and powder coated.
Bearing extraction, also clear both sides have been removed before. The criss cross pattern on the bearing casing gives this away.
main three items ready for coating. All looking in good condition.
We next inspected the drive shafts. The drivers side had been replaced but with an older shaft that had clearly had a tough life. God knows how the rubbers twist.
both ends had holes in, were surprised it didn’t spray grease everwhere.
we’ll need to order a gator rebuild kit, we keep non M gators in stock so you can at least see what they look like.
We also removed the old fuel tank straps. Looking tired but still intact.
So this leaves the back end completely bare. She’ll get a good clean up and under-sealing on the seams.
As I said before you can see it’s life history if you look close. I hear these coupes can pull their roll bar mounts off and it looked like Mr pigeon paid a visit to repair.
Diff hanger looking ok. Will check the boot floor at some point.
Another little job I did was check the front discs. They had quite a large lip. If you look closely on the hub it gives a minimum thickness of 26.4mm we only have 1mm left not great for spirited driving as they don’t dissipate heat well.
Reached photo limit :D
Messages
3,879
Z3 Roadie 2.8TU
Last job of the day was removing the front subframe. Looks so odd seeing the engine floating.
Front subframe on the bench. 4 main bolts and two bolts holding the rack.
View from underneath.
Engine mounts looking tired so might be worth an upgrade. These really transform the way it feels, I fitted some vibratek mounts to mine.
So tonight will be a mass order of parts, mostly from BMW and some Bilstein goodies. The powder coaters will love me next week as my boot is full.
137699
Messages
139
Great to see the ZedShed first hand today and meet the team working on my car!
So very pleased you're doing this work now - seeing how tired so much of the componentry is - this overhaul is not before time!
Looking forward to seeing the shiny stuff soon!
andyglym
Messages
19,972
It'll be like night and day mate, these guys are wizards.
Messages
3,879
Z3 Roadie 2.8TU
Only a little update today. All the parts have been ordered and all the metalwork is at the coaters. They’re running a bit behind at the coaters but fingers crossed I get bits back for this weekend.
Messages
3,879
Z3 Roadie 2.8TU
Finally got everything back from the powder coaters. The guys there are crazy busy, plus they had quite a few bits from me, two cars worth. I’ve also found ordering parts for Z3M’s now becoming a problem, I might of just bought the last front shocks in the country, I’ve had 3 purchases cancelled due to stock, even Bilstein rang me to say they have no stock world wide for the Z3M and don’t expect to till June.
The wagon filled to the brim.
first up was a stock take and check everything.
everything looks great.
First job was getting the engine sat back on the subframe. Also fitting the new engine mounts.
these are far easier to install fitted to the subframe. Also new bolts for the subframe. One engine mount has a heat shield due to the close proximity of the exhaust manifolds.
looking pretty on fresh mounts, now a lot stiffer.
next up was the wishbones. I reused the lollipop brackets and fitted new bushes.
drivers side is always a pain to do up, made so much easier with the roll bar out the way. Once these were on I fitted the steering assembly. The M has a unique looking tab so make sure she’s locked.
locking done, stops rotation.
lots of shinny bits.
now with the roll bar in place. Not much more I can do now till I have shocks.
This is the first time I’ve had the knuckles coated, they’ve come up really well.
Next job was fitting the new hardware to the diff. The oil in this stuff seriously stinks my garage out for hours.
cover removed. (Oil to be replaced later)
There was a right mix of old gasket and old sealant. Took a bit of time to remove it all and re flatten the surface again ready for a new gasket.
All these items need painting now, didn’t notice I was out of brushes so that will have to wait a few days. I also fitted the new tank straps, just getting all the little jobs out the way. I reckon she will be very nearly finished this weekend.
Also some photos, copied over from the drive shaft thread. I used the BMW drive shaft repair kit, god knows how this shaft got in such a bad way. Was a very simple job just very messy.
Twisted boot.
All removed and new boots fitted with new clips.
Diff end.
Whole shaft. As much as it would be nice to redo both shafts these kits are very pricey so I would recommend doing them only if you really need too.
This weekend will be rear subframe install.
